• 26.04.2024, 16:29
AMD's HAMMER DRAUSEN!
Mittwoch, 27. Februar 2002, 14:48
Ja, richtig gelesen! Völlig überraschend hat AMD der Weltöffentlichkeit heute die erste Demonstration seinen neuen 64-Bit Boliden 'Hammer' präsentiert:
AMD (NYSE: AMD) today demonstrated our vision of the future of computing with our next-generation processor, codenamed "Hammer."
"Great architectures are built on strong foundations, and 'Hammer' is rock solid. Based on AMD's x86-64 technology, the 'Hammer' processor will be the industry's first and only 64-bit processor for x86 computing, and is designed to offer unparalleled performance on both 32-bit and 64-bit software," said Ed Ellett, vice president of Marketing for AMD's Computation Products Group. "Beyond performance, 'Hammer' will give users a smooth migration path to the 64-bit software of tomorrow, all the while preserving the billions of dollars of today's 32-bit software applications."
"Hammer" processors are expected to be AMD's first x86 processors to have a fully integrated DDR memory controller and "Hammer" processor-based solutions are expected to be the first to incorporate a full HyperTransport™ technology-based chipset. Both technology advancements help remove bottlenecks and speed the flow of information through the PC. The "Hammer" processor family will also be extremely versatile, with processor versions planned to power systems from thin-and-light notebooks to 8-way enterprise servers.
AMD's demonstration featured "Hammer" running both a 64-bit Linux and 32-bit Microsoft® Windows® operating system. The AMD "Hammer" processors were manufactured on 0.13 micron, Silicon on Insulator (SOI) technology, which together enable higher performance and lower power consumption.
"'Hammer' remains true to AMD's traditions. We're innovating within industry standards, innovating with compatibility, and innovating with users in mind," said Fred Weber, Chief Technical Officer of the Computation Products Group of AMD. "Because it is based on the long-established x86 instruction set architecture, software developers, engineers and IT personnel don't have to start over from scratch."
AMD expects to begin shipping the first version of the "Hammer" family of processors at the end of 2002.
Das komplette Original der Pressemitteilung...
Damit hat AMD mal wieder alle genarrt. In der Gerüchteküche - und die ist normalerweise äußerst kühn unterwegs - glaubte man zu wissen, AMD werde den Hammer erstmals auf der CeBIT im stillen Kämmerlein vorführen, während AMD auf Anfrage gar stets auf Ende (!) 2002 verwies; ein frühes Vorpreschen werde es nicht geben. Und nun das. Wie es scheint ist die Arbeit an der gesamten Hammer-Plattform wesentlich weiter fortgeschritten, als man der Presse glauben machen wollte.
Dennoch wird AMD allem Anschein nach an der bekannten Roadmap festhalten und die Zeit bis zum offiziellen Launch Ende 2002 dazu nutzen, mit der neue CPU-Generation im Köfferchen einen Werbefeldzug ohnegleichen starten. Den ersten 64-Bit x86-Prozessor der Welt feuert man schließlich nicht einfach ab und legt ihn tags drauf kommentarlos in die Ladenregale. In unserer aktuellen Umfrage scheinen die meisten unserer Leser den Hammer zwar händeringend zu erwarten, doch der Planet 3DNow! darf hier sicher nicht als repräsentativ gelten. Den Rest der Welt gilt es für AMD von der Notwendigkeit der neuen Technologie zu überzeugen. Die frühe Fertigstellung wird AMD dabei ungemein helfen, ebenso wie die Eignung des Hammer auch als schnelle 32-Bit CPU zu fungieren, die - wie damals der 80386 mit DOS - dank effizienzsteigernder Maßnahmen an der Architektur auch mit bestehender Software schneller sein wird, als der letzte Vertreter der Vorgänger-Epoche (damals 16-Bit 80286)...
THX @The Ch@se & Christian für den Hinweis :-)
[ALL FROM http://www.planet3dnow.de]
Re: AMD's HAMMER DRAUSEN!
Mittwoch, 27. Februar 2002, 15:24
Mittwoch, 27. Februar 2002, 16:56
link funzt net ;)
Mittwoch, 27. Februar 2002, 17:03
wenn nicht dann vieleicht mit rechte maustaste Verknüpfung kopieren auswählen und in neues fenster einfügen!
hoffentlich klappt es!
Mittwoch, 27. Februar 2002, 17:21
LOL
DA WAR WOHL EINER SCHNELLER!!!!!!!
Mittwoch, 27. Februar 2002, 18:25
"draussen" zu sagen is bissel übertrieben
Mittwoch, 27. Februar 2002, 18:30
@ MassiveBlue
Ein rezitieren des gesamten Artikels, der bereits oben steht, ist unnötig lang und nicht angebracht.
Mittwoch, 27. Februar 2002, 19:10
Zitat von »Bluefake«
@ MassiveBlue
Sorry, hab das wohl vergessen, dass der text ein wenig lang ist. :o
Mittwoch, 27. Februar 2002, 20:42
also "draußen" nenn ich das noch lange nicht :)
aber schaut nett aus.... das referenzboard is hübsch, kewle farbe!
interessant auch: kein NB-kühler! hams die inzwischen so hingekriegt, daß sie keine xxx°C mehr heiß wird?
armer twinplex, wird er wohl überflüssig ;)
aufruf an aqua: wie schauts aus, wann kommt der HAMMERPLEX? ;D ;D ;D
Donnerstag, 28. Februar 2002, 11:17
Sorry, 1000 Euro für eine CPU ist absolut nicht akzeptabel für den Heimgebrauch, aber vielleicht lernt mal AMD endlich das man mit CPUs auch Geld verdienen kann wenn man nicht Ständig versucht Intel zu unterbieten.
Schöne Grüße
Roland
BBB
Donnerstag, 28. Februar 2002, 16:17
Das beste ist ja das hier, ein kleiner Artikel von www.computerbase.de
AMD macht sich über Intel lustig
Man sollte es kaum glauben, aber die Präsentation von AMDs Hammer war von langer Hand geplant, denn AMD hat bei der Präsentation noch ein Schmankerl eingebaut, das erst bei genauem Hinsehen sichtbar wird und sich auf dem SOLO2 Mainboard versteckt.
Auf dem Bild wird es deutlich, unter den beiden Aufklebern und über dem AMD Schriftzug ist ein kleines Notenfeld aufgedruckt. Wie die Musik-Profis im Netz bereits festgestellt haben, handelt es sich um die Intel "Token" Musik, die bei jeder Werbung von Intel zu hören ist.
[img]http://images.anandtech.com/reviews/shows/2002/SpringIDF/day 2/hammer/solo3.jpg[/img]
8)
