Sie sind nicht angemeldet.
Xtrem
das habe ich bei Seves´s digicamrev. gefunden. also Stimmts? HILFEEEEEEE!!!Zitat
The S404 is equipped with a CompactFlash Type I card slot and comes with a 16MB CF card, it's compatible with any brand or capacity of CF card.
The S404 is equipped with a CompactFlash Type I card slot which means that it can't use a Microdrive but you can use up to a 512MB card and soon, one-gigabyte sized CF cards will be on the market
