Sie sind nicht angemeldet.
DDR-333
However it is hard for DDR333s to perform as expected with the current AMD CPUs. While AMD CPUs use 133 MHz. FSB to communicate with KT333, the rate between RAMs and KT333 is 166 MHz. This means that the mobo is working asynchronous and the CPU causes a bottleneck effect. This problem will be solved as AMD releases CPUs with 166 MHz. FSB. Some mobo manufacturers have already installed jumpers to switch between 166 and 133 MHz. FSB. But we still can’t see 166 MHz. CPU’s in AMD’s roadmap. Even 0.13micron Thoroughbred’s will be 133 MHz.
