Sie sind nicht angemeldet.
Zitat von »EpS«
Q. What slots do i put my memory in to enable Dual Channel DDR (TwinBank)?
A. The manual says for 1 stick to reside in each channel. What that means is to benefit from DCDDR you should place modules in slots 1 & 3, or slots 2 & 3. Slot 1 is located closest to the Ziff Socket (black in color) slot 2 is next (blue) and slot 3 is next (also blue). Using all 3 slots can also enable DCDDR. People’s results have varied from system to system depending on what slots they put their modules in. Some get better performance with a certain configuration and some get better stability with another. You should try your own tests as they will more then likely differ from others.
Q. How do I set up Dual Channel DDR/TwinBank/DualDDR optimally?
A. In order for DualDDR memory to run at it's optimal speed, you need to have an equal amount of RAM in each channel. Slots 1 and 2 are channel 1, and slot 3 is channel 2. Right now I've got 256MB in slot 2, and 256MB in slot 3. This means 256MB in each channel. If I was to upgrade and wanted to keep full Dual DDR, I would need a 512MB stick, and put it in slot 3, and the 256MB sticks in slots 1 & 2. This would give me 512MB in each channel, and an equal balance. This would give me an optimal Dual DDR setup.
If I were to have, say, 512MB in one channel, and 256MB in the other, only 256MB of the channel with the 512MB stick would be running in Dual DDR, since the channels would not be balanced. The rest of the 512MB stick would run in standard single channel mode, giving below optimal performance.
;D ;D
scheint doch zu gehen. und es ist wohl sogar die beste möglichkeit dual ddr zu nutzen. *jipie*
