also ich versuch mal die fragen soweit ich kann zu beantworten, wie gesagt ist das eigentlich nicht so mein gebiet.
also an dem server an sich an einem controller hängen 2 platten die laufen auch ohne probleme nur halt die beiden neuen lassen sich nicht mounten (hängen an nem 2ten controller, normaler scsi-controller, meines wissens nach).
unser admin hat auch nochmal nen test laufen lassen, wobei folgendes rauskam:
sc> poweron
SC Alert: Host System has Reset
sc> console -f
Warning: User < > currently has write permission to this console and forcibly removing them will terminate any current write actions and all work will be lost. Would you like to continue? [y/n]y
Enter #. to return to ALOM.
SC Alert: PSU @ PS0 has FAILED.
screen not found.
keyboard not found.
Keyboard not present. Using ttya for input and output.
Sun Fire V440, No Keyboard
Copyright 1998-2004 Sun Microsystems, Inc. All rights reserved.
OpenBoot 4.13.0, 16384 MB memory installed, Serial #xxxxxxxx.
Ethernet address x:x:xx:xx:xx:xx, Host ID: xxxxxxxx.
{3} ok probe-scsi-all
/pci@1f,700000/scsi@2,1
Target e
Unit 0 Disk HITACHI HUS103030FL3600 SA1B 585937500 Blocks, 286102 MB
Target f
Target 0
Unit 0 Disk SEAGATE ST373307LSUN72G 0507 143374738 Blocks, 70007 MB
Target 2
{3} ok test-all
Testing /pci@1f,700000/scsi@2,1
Testing /pci@1f,700000/network@1
Testing /pci@1e,600000/ide@d
Testing /pci@1e,600000/usb@b
Testing /pci@1e,600000/usb@a
Testing /pci@1e,600000/isa@7/rmc-comm@0,3e8
Testing /pci@1e,600000/isa@7/serial@0,2e8
Testing /pci@1e,600000/isa@7/serial@0,3f8
Testing /pci@1e,600000/isa@7/i2c@0,320
Testing /pci@1e,600000/isa@7/rtc@0,70
Testing /pci@1e,600000/isa@7/flashprom@2,0
Testing /pci@1c,600000/network@2
{3} ok watch-clock
Watching the 'seconds' register of the real time clock chip.
It should be 'ticking' once a second.
Type any key to stop.
37
{3} ok watch-net-all
/pci@1f,700000/network@1: link down
/pci@1c,600000/network@2: 1000 Mbps full duplex link up
Watch ethernet packets
'.' is a good packet and 'X' is a bad packet
Press any key to stop
{3} ok boot
screen not found.
keyboard not found.
Rebooting with command: boot
Boot device: /pci@1f,700000/scsi@2/disk@0,0:a File and args:
SunOS Release 5.10 Version Generic_120011-14 64-bit
Copyright 1983-2007 Sun Microsystems, Inc. All rights reserved.
Use is subject to license terms.
Hardware watchdog enabled
Hostname: nyx
/dev/rdsk/c1t2d0s0 is clean
/dev/rdsk/c1t0d0s3 is clean
nyx console login: Oct 1 15:41:14 nyx sendmail[404]: My unqualified host name (nyx) unknown; sleeping for retry
Oct 1 15:41:14 nyx sendmail[405]: My unqualified host name (nyx) unknown; sleeping for retry
nyx console login:
sc> poweron
sc> console -f
screen not found.
keyboard not found.
Target e
Target f
Target 0
Target 2
{3} ok boot -r
Boot device: /pci@1f,700000/scsi@2/disk@0,0:a File and args: -r
Hostname: nyx
Configuring devices.
WARNING: /pci@1f,700000/scsi@2,1 (mpt1):
Disconnected command timeout for Target 14
Disconnected command timeout for Target 15
nyx console login: Oct 1 17:37:04 nyx sendmail[481]: My unqualified host name (nyx) unknown; sleeping for retry
Oct 1 17:37:04 nyx sendmail[482]: My unqualified host name (nyx) unknown; sleeping for retry
vermutlich ein HDD-Firmware Problem wenn wir dasrichtig interpretiert haben.
Tante €dit sagt:
hier habt ihr auch nochmal die dmesg.out:
Oct 1 18:13:07 nyx scsi: [ID 365881 kern.info] /pci@1f,700000/scsi@2,1 (mpt1):
Oct 1 18:13:07 nyx initiator SCSI ID now 7
Oct 1 18:13:07 nyx Rev. 7 LSI, Inc. 1030 found.
Oct 1 18:13:07 nyx mpt1 supports power management.
Oct 1 18:13:07 nyx pseudo: [ID 129642 kern.info] pseudo-device: ramdisk1024
Oct 1 18:13:07 nyx genunix: [ID 936769 kern.info] ramdisk1024 is /pseudo/ramdisk@1024
Oct 1 18:13:07 nyx mpt1 Firmware version v1.3.27.0 (IM/IME)
Oct 1 18:13:07 nyx mpt1: IOC Operational.
