Hi Shoggy,
Ive found a great LCD app called LCDHost that is much easier to use than LCDHype and I was hoping you guys are going to allow data export in XML or log files from Aquasuite 2012 so we can create some cool screens for G13/G15/G19 keyboards?
It also supports a few different LCDs so you might be able to work with the developer to port your LCDhype plugin to LCDHost.
Heres one I put together tonight that it would be cool to add data from the A5 to.
Dataviewer tool for XML in LCDHost
