• 22.05.2012, 01:08
iBeta2
Aquastream problems after suspend (S3 state)
Saturday, January 21st 2012, 12:24am
Nearly every resume from sleep results in AquastreamXT causing either Aquasuite to crash, or else the Aquastream temp. chart has dashes where the statistic numbers should be. The only way to get back is to restart Aquasuite, after which all sensor/fan etc names and settings are unavailable in Aquasuite. However the charts work, and I usually leave it like this as there are no problems after a resume.
Getting the information back into Aquasuite requires a reboot (or disconnecting/connecting the USB), and it is fine until the next S3 state.
This (or variations of) have occurred in Beta11/10/9, I'm hoping it's because Aquastream isn't fully supported yet - ie you can't flash the fw from Aquasuite, But if there could be other problems it would be good to know, as this is getting painful.
Btw, I must of disconnected, then reconnected the usb header about 2012 times by now :rolleyes: If technically possible, couldn't Aquasuite have a 'disconnect/reconnect' button for the USB connection?
