• 22.05.2012, 22:36
etoel
Aquatream XT internal temp vs tank temp
Tuesday, March 18th 2008, 4:39pm
Hi there, there is a constant 3C difference between the reported temp from the pump itself and the external sensor on the tank. What is he pump measuring? The water passing through the pump or the pump (internal) temp?
