• 22.05.2012, 22:54
SteinerKD
Cosmos S and radiators
Saturday, June 28th 2008, 4:30am
Hi (me again ;) ).
Anyone here use a CoolerMaster Cosmos S case with AC radiators??
I'm curious about the top footprint (supposed to be room for 3 fans/tripple radiator in the roof). Does the dual/tripple radiators fit (well?) there and if so how thick radiators can you use there? (from what I've gathered there's room for a tripple hanging on the roof with 3 fans on the outside under the ventilated plastic cover. not optimal as the fans would be in pull instead of push mode).
What other rad options are there with it? Seems to be a back and a bottom spot where you could probably use a 120 single rad.
Possibly you could also hang a double, or tripple even, rad from the HD cage with the mounting kit of if you make your own mounting holes against the back wall (passive though) between mobo and hd cage. Any thoughts or experience?
