Hi.
I would guess that the problem is the initial current or voltage.
The operating current is rated at 0.15 amps but this does not mean that the fan is able to start with this current. You may need a higher initial voltage. -
Try the following: activate the start boost for this fan.
btw:
what is a "mist fan"? I never heard this before.
for a good speed control, you need a fan with a startup power from 30% .. 50%.
With your fan (startup power 80%) you have a vary limited control range 80 .. 100%.
