• 26.04.2024, 03:16
NEXT CPU Water temp sensor not in sensors in Aquasuite?
Donnerstag, 14. November 2019, 00:57
I have a cpu water block the CUPLEX KRYOS NEXT WITH VISION i also have the Aquaero 6 XT controller. Am trying to set the fan curve in Aquasuite but in “Sensors” I don’t see the option for the Next cpu water block which has a built in water temperature sensor and I want to use the fan curve with the water temperature sensor.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Shadowman« (14. November 2019, 00:59)
Donnerstag, 14. November 2019, 07:26
Option 1: when you connect the vision via aquabus.
Option 2: create a software sensor (aquaero 6 sensors tab) ab forward the temperature via USB to the aquaero
Donnerstag, 14. November 2019, 15:13
Thank you very much, really appreciate the help.
