• 20.04.2024, 06:25
Connected USB devices
Sonntag, 9. Mai 2021, 04:52
I have an Aquaero 6 XT I cannot install the application, it is connected to one of my USB ports.
Give me the following message:
No Aqua Computer USB devices found.
Check the USB connection of your devices.
The aquasuite can not be used without connected USB devices!
I know you have to install Microsoft NET Framework 4.6.1, but it does not install. Following message:
NET Framework 4.6.1 or a later update has already been installed on the computer.
::.I7-10700k 5.1 Ghz | Asus Maximus XII Formula | GTX 1080 Ti ASUS POSEIDON.::
::.32GB Corsair Dominator Platinum RGB 3000 Mhz | WaterCooler Custom.::
::.Teclado MadCatz S.T.R.I.K.E.7 | Mouse M.M.0.7.::
::.2X SSD HyperX Savage x 250GB RAID0.::
::.Fonte Corsair AX1200W | Cosmos II.::
Montag, 10. Mai 2021, 08:40
Ensure your device is connected via USB. Check the usb cable polarity on both sides. (Mainboard and device)
Try to unplug all other USB devices.
Close ALL other software ans try it again.
