• 29.05.2024, 09:00
ULTITOP DUAL D5
Montag, 29. Mai 2023, 13:41
Hello,
I’m very interested in this product https://shop.aquacomputer.de/product_inf…roducts_id=3945.
But I wonder if it is possible to add a reservoir in the top and if it is, which reservoir to buy ?
Thank a lot in advance. :)
Montag, 29. Mai 2023, 20:32
Hmmm. That is a good question! I don't see any way that you could directly connect a reservoir to this. Normally, a reservoir has to be mounted directly above the pump but I don't see how you could do this with this dual D5 pump adapter. I did a Google image search and could not find a picture of 2 pumps connected to this pump adapter with a reservoir.
Montag, 29. Mai 2023, 21:11
Hello,
Thanks for your help :)
It is rather strange. Can Aquacomputer staff answer us about it on this forum ? ;)
Thanks
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Pegase« (29. Mai 2023, 21:12)
Dienstag, 30. Mai 2023, 06:06
There is no "matching" reservoir, you can use any stand alone reservoir and connect it via a tube, hardtube or fittings.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Taubenhaucher« (30. Mai 2023, 06:07)
Dienstag, 30. Mai 2023, 08:04
That is OK. Thank you for your answer. :)
