Sie sind nicht angemeldet.
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 |
# # Quadro sensors configuration file # This file should be used with /etc/sensors.d/* customize files # # Copyright Daniel Mehrmann (Akusari) # # Aquacomputer Quadro# Chipset: ??? # chip "quadro-*" ### customize ### ## fan section ## label fan4 "Water Pump" set fan4_min 2000 set fan4_max 4550 label fan1 "Front Fan" set fan1_min 300 set fan1_max 2450 label fan2 "R280 Top Fan" set fan2_min 300 set fan2_max 1950 label fan3 "R120 Backend Fan" set fan3_min 300 set fan3_max 1650 ## sensor section ## label temp1 "Water Temp" label temp2 "VRM CPU" label temp3 "VRM SoC" ### ignore section ### # flow sensor ignore fan5 # sensor 4 ignore temp4 # virtual sensors 16-1 ignore temp20 ignore temp19 ignore temp18 ignore temp17 ignore temp16 ignore temp15 ignore temp14 ignore temp13 ignore temp12 ignore temp11 ignore temp10 ignore temp9 ignore temp8 ignore temp7 ignore temp6 ignore temp5 |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 |
[daniel@daten-box]~$ sensors nct6798-isa-0290 Adapter: ISA adapter Vcore: 480.00 mV (min = +0.20 V, max = +1.50 V) SYSTIN: +30.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) sensor = thermistor CPUTIN: +29.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +80.0°C) sensor = thermistor AUXTIN0: +8.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) sensor = thermistor AUXTIN1: -62.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) sensor = thermistor AUXTIN2: +13.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) sensor = thermistor AUXTIN3: +31.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) sensor = thermistor AUXTIN4: +26.0°C (high = +80.0°C, hyst = +75.0°C) (crit = +0.0°C) SMBUSMASTER 0: +41.0°C (high = +80.0°C, hyst = +75.0°C) PCH_CHIP_CPU_MAX_TEMP: +0.0°C PCH_CHIP_TEMP: +0.0°C PCH_CPU_TEMP: +0.0°C PCH_MCH_TEMP: +0.0°C TSI0_TEMP: +41.1°C beep_enable: disabled k10temp-pci-00c3 Adapter: PCI adapter Tctl: +40.9°C Tccd1: +27.8°C Tccd2: +32.2°C nvme-pci-0100 Adapter: PCI adapter Composite: +33.9°C (low = -0.1°C, high = +84.8°C) (crit = +94.8°C) Sensor 1: +33.9°C (low = -273.1°C, high = +65261.8°C) Sensor 2: +40.9°C (low = -273.1°C, high = +65261.8°C) Sensor 8: +33.9°C (low = -273.1°C, high = +65261.8°C) amdgpu-pci-0a00 Adapter: PCI adapter vddgfx: 6.00 mV fan1: 0 RPM (min = 0 RPM, max = 2700 RPM) edge: +28.0°C (crit = +110.0°C, hyst = -273.1°C) (emerg = +115.0°C) junction: +28.0°C (crit = +110.0°C, hyst = -273.1°C) (emerg = +115.0°C) mem: +32.0°C (crit = +105.0°C, hyst = -273.1°C) (emerg = +110.0°C) PPT: 5.00 W (cap = 194.00 W) quadro-hid-3-6 Adapter: HID adapter Fan 1 voltage: 12.06 V Fan 2 voltage: 12.06 V Fan 3 voltage: 12.06 V Fan 4 voltage: 12.06 V Front Fan: 862 RPM R280 Top Fan: 454 RPM R120 Backend Fan: 700 RPM Water Pump: 2746 RPM Water Temp: +26.0°C VRM CPU: +31.2°C VRM SoC: +29.4°C Fan 1 power: 510.00 mW Fan 2 power: 80.00 mW Fan 3 power: 300.00 mW Fan 4 power: 0.00 W Fan 1 current: 43.00 mA Fan 2 current: 7.00 mA Fan 3 current: 25.00 mA |
Wenn ich das richtig sehe, dann schreibst Du damit nur den Output des Kernelmoduls auf fuer Dich sinnvollere Bezeichnungen um, damit "sensors" die dann anzeigt. Kann man machen.
Das schoene am Kernelmodul ist aber ja, dass die aquacomputer-devices unter /sys/class/hwmon auftauchen. Das mache ich mir zunutze, um dort die Daten abzugreifen und in die Datenbank zu schreiben. Mit dann auch eigenen Bezeichnungen.
Irgendwie eleganter, als den output von "sensors -j" mit jq zu durchwuehlen.
Also jetzt falls Du vorhast, die Daten irgendwo ausserhalb von "sensors" einsehen zu wollen.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Akusari« (11. Januar 2024, 07:56)
