Sie sind nicht angemeldet.
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 |
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.InvalidOperationException: The provider could not determine the Object value. For example, the row was just created, the default for the Object column was not available, and the consumer had not yet set a new Object value. at System.Data.OleDb.ColumnBinding.Value() at System.Data.OleDb.OleDbDataReader.GetValues(Object[] values) at System.Data.ProviderBase.DataReaderContainer.CommonLanguageSubsetDataReader.GetValues(Object[] values) at System.Data.ProviderBase.SchemaMapping.LoadDataRow() at System.Data.Common.DataAdapter.FillLoadDataRow(SchemaMapping mapping) at System.Data.Common.DataAdapter.FillFromReader(DataSet dataset, DataTable datatable, String srcTable, DataReaderContainer dataReader, Int32 startRecord, Int32 maxRecords, DataColumn parentChapterColumn, Object parentChapterValue) at System.Data.Common.DataAdapter.Fill(DataTable[] dataTables, IDataReader dataReader, Int32 startRecord, Int32 maxRecords) at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) at AquaComputer.Database.DbAccess.GetWindowParamter(Int32 DeviceID, TWindowParameterStruct& WindowParameter) at AquaComputer.Database.DbAccess.LoadWindowParameter(TWindowParameterStruct& WindowParameter, Form& Form, DbAccess DbIntern) at AquaComputer.Forms.frm_Main.CreateDeviceWindows() at AquaComputer.Forms.frm_Main.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- aquasuite Assembly Version: 4.53.2966.21978 Win32 Version: 4.54.00 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/aquasuite.exe ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- WindowCommunication Assembly Version: 1.0.2966.21958 Win32 Version: 1.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowCommunication.DLL ---------------------------------------- Database Assembly Version: 2.0.2966.21956 Win32 Version: 2.0.2966.21956 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/Database.DLL ---------------------------------------- USB Assembly Version: 2.0.2956.25538 Win32 Version: 2.0.2956.25538 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/USB.DLL ---------------------------------------- SandBar Assembly Version: 1.4.0.1 Win32 Version: 1.4.0.1 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/SandBar.DLL ---------------------------------------- |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 |
System.Deployment Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll ---------------------------------------- Interop.JRO Assembly Version: 2.6.0.0 Win32 Version: 2.6.0.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/Interop.JRO.DLL ---------------------------------------- System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll ---------------------------------------- System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- myTranslationClasses Assembly Version: 2.50.2957.16459 Win32 Version: 2.50.2957.16459 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/myTranslationClasses.DLL ---------------------------------------- WindowTubemeter Assembly Version: 2.0.2966.21968 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowTubemeter.DLL ---------------------------------------- WindowMultiswitch Assembly Version: 2.0.2966.21965 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowMultiswitch.DLL ---------------------------------------- WindowAquaero Assembly Version: 2.0.2966.21962 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaero.DLL ---------------------------------------- WindowAquaduct Assembly Version: 2.0.2966.21969 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct.DLL ---------------------------------------- WindowPoweradjust Assembly Version: 2.0.2966.21965 Win32 Version: 1.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowPoweradjust.DLL ---------------------------------------- WindowAquastream Assembly Version: 2.0.2966.21972 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquastream.DLL ---------------------------------------- WindowAquaduct240Pro Assembly Version: 2.0.2966.21973 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct240Pro.DLL ---------------------------------------- WindowAquaduct360mk2 Assembly Version: 2.0.2966.21975 Win32 Version: 2.0 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/WindowAquaduct360mk2.DLL ---------------------------------------- ControlLibrary Assembly Version: 2.1.2946.31133 Win32 Version: 2.1.2946.31133 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/ControlLibrary.DLL ---------------------------------------- AquaComputer.Graph Assembly Version: 5.0.3.31133 Win32 Version: 5.0.3.31133 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/AquaComputer.Graph.DLL ---------------------------------------- SandDock Assembly Version: 2.4.0.1 Win32 Version: 2.4.0.1 CodeBase: file:///C:/Program%20Files/Aqua%20Computer/aquasuite/SandDock.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 |
************** Exception Text ************** System.Data.OleDb.OleDbException: Unrecognized database format 'C:\Documents and Settings\All Users\Application Data\Aqua Computer\aquasuite\database\aquasuitedata.mdb'. at System.Data.OleDb.OleDbConnectionInternal..ctor(OleDbConnectionString constr, OleDbConnection connection) at System.Data.OleDb.OleDbConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject) at System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup) at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) at System.Data.OleDb.OleDbConnection.Open() at System.Data.Common.DbDataAdapter.FillInternal(DataSet dataset, DataTable[] datatables, Int32 startRecord, Int32 maxRecords, String srcTable, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable[] dataTables, Int32 startRecord, Int32 maxRecords, IDbCommand command, CommandBehavior behavior) at System.Data.Common.DbDataAdapter.Fill(DataTable dataTable) at AquaComputer.Database.DbAccess.GetWindowParamter(Int32 DeviceID, TWindowParameterStruct& WindowParameter) at AquaComputer.Database.DbAccess.LoadWindowParameter(TWindowParameterStruct& WindowParameter, Form& Form, DbAccess DbIntern) at AquaComputer.Forms.frm_Main.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) |
