Hab heute durch Zufall dies hier gefunden: DualDDR Support:
In an earlier revision of this review, I reported that ABIT's manual recommends that the DDR DIMM slots be filled in the order of DIMM3 to DIMM1. However, the information printed in that manual is wrong! Here's why.
NVIDIA's DualDDR technology relies on two separate memory controllers to double its memory bandwidth. There is a twist though. The first memory controller only controls the first DIMM slot while the second memory controller handles the last two DIMM slot. To enable DualDDR, you must use up two DIMM slots and one of them must be DIMM1. If you insert the two DIMMs in DIMM2 and DIMM3, you will be using only one of the nForce2's two memory controllers. That's why ABIT is wrong in recommending that the DIMM slots be populated in the reverse order of DIMM3 to DIMM1.
Now, it should be noted that it is not necessary for you to follow any particular order. I tried the following DIMM configurations - (DIMM1+DIMM2), (DIMM1+DIMM3), just DIMM1 and just DIMM2. They all worked fine so there shouldn't be a problem if you do not follow the recommended order. However, if you are using two DIMMs, make sure you insert one of them into DIMM1. The other can be in DIMM2 or DIMM3. Either way, DualDDR support will be enabled.
Jetzt ist nur die Frage wer Recht hat! Hat Abit tatsächlich geschlampt oder liegt der Autor falsch? Ich bin echt nicht mehr sicher wann Twinbanking aktiviert ist und wann nicht! Schreibt mal bitte eure Erfahrungen hier hin! Da ich Morgen das Board bekommen werde!
