hmmm
najo
es gibt vieeeele tests und daher auch viele unterschiedlich ergbenisse.....
http://www.bit-tech.net/review/284
"What of accuracy? Well this is the one area Microsoft have made a real improvement. This thing feels just as good as the MX700. Using Mouse Rate Checker the v2 appeared to be refreshing at around 110Hz - slightly lower than the 125Hz measured by the MX700, making it ever so slightly less precise, technically. However, I can tell you this - I am extremely picky about my mice, and am extremely fussy about mousing accuracy for PhotoShop work and gaming. I have no hesitation in using this mouse above all others, because it runs like a dream. No lag, pixel-perfect precision - sweet as."
dort schneidet die recht gut ab!
ich persönlich kann auch sagen das die von der genauigkeit nimmer viel mit den alten mäusen von ms gemeinsam hat!
ich hab die mit kabel und kann die nur empfehlen
