Du musst in der Serverconfig vom Betriebsmode Gatewaybetieb aufn Router umstellen!!!!
Operating Mode
Choose the correct working mode. Keep the default setting, Gateway, if the Router is hosting your network’s connection to the Internet (Gateway mode is recommended for most users). Select Router if the Router exists on a network with other routers
Aus der Linksys-help.
