• 17.11.2026, 16:10
snippy
Re: An English WaKue
Dienstag, 12. August 2003, 14:27
Zitat von »DSEDS«
Outstanding cable management. :) Great work.
Yo!
Great Mod. Very fine.
But the thing I like the most is the cable management, as DSEDS said... it's .....  :o ;D
Would you please post some pictures that show, how you managed that problem???
@ DSEDS: Please change you nick.. it spontaneusly reminds me at "Deutschland sucht den Superstar" and the show sucked ;D
THX and Cu
Cartman87654
Dienstag, 12. August 2003, 15:16
wow very nice Casemod ;)
my english ist very bad ;D
WizardD
Dienstag, 12. August 2003, 20:50
@ Manuel - those cases do look nice - I'm not sure how I could make them look much better though. ;D
@ DSEDS & snippy - my hardest problem was probably with the RS232 Serial lead for the CrystalFontz display.
It would have been easier if was USB - I could have made a cable to go to the motherboard pins but I made a slot for it next to the PSU and it plugs in the back instead.
All the loose cable is behind the motherboard tray except the Eheim pump cable - I cut off the plug and soldered a 3 pin socket to it, which is now mounted above the PSU.
(I use two power leads now).
I used polyester sleeving and heatshrink to manage the PSU cables by taking the pins out from the 12v/5v molex connectors but I found the main ATX lead (stromstecker?) more difficult to do, so I did this...
... and just used the polyester sleeve with a cable tie (instead of heatshrink) for now.
Here you might see the cabling better
and here is a closer look at the inside
The front panel connector was the easiest one to do... ;)
@Cartman - ...very nice avatar. ;D 8)
Please excuse my English - I'm English. :)
Zitat von »Manuel_aka_Auge«
Different from the others, that´s the meaning of case-modding.
DCC
Dienstag, 12. August 2003, 23:11
joa mei, des is a wahnsinn, sog i jetzt ma soa. ;D
n1c3 work!
[glow=red,2,300]EBAY[/glow]
DSEDS
Mittwoch, 13. August 2003, 02:43
THX and Cu
Sorry, ich hatte meinen Namen früher. Die sollen ihren Namen ändern. ;D
Jackrip5
Mittwoch, 13. August 2003, 02:53
Simply impressive - wow what for a good work !!
The.dirk
Mittwoch, 13. August 2003, 03:56
Verkaufe AMD Hitpipe Kühler(15€) und 2 120er Alu Titan Lüfter(18€ für beide). VB KM schreiben
Dr._Mohr
Mittwoch, 13. August 2003, 23:45
WOW :o
nice work :D
syr 4 my bad english ;D
WizardD
Donnerstag, 14. August 2003, 00:30
Danke alle. :)
Traurig für meinen schlechten Deutschen (I hope that says it right)
The.dirk
Donnerstag, 14. August 2003, 01:55
ok ... it´s not bad ::) but my is better :) i think the feet of your case are n1 .
will ich auch haben
so long dirk
WizardD
Donnerstag, 14. August 2003, 14:12
Ah, I forgot to say - the case feet are from a Pioneer CT-W504R twin cassette deck. ;D
The chieftec feet are in the way of the radiator otherwise, so they had to go...
(and sadly that was not my German - it was Babelfish' :-[) ;)
0815God-Modder
Donnerstag, 14. August 2003, 15:26
very nice.
nice Front-mode
sry 4 my bad english
ca.1m langes Modell des Ferrari Enzos. Wenn ihr irgendwo 1 seht oder eures hergeben wollt KM an mich
Zitat von »Hayes«
Was ist das denn für ein lustiges NT mit drei Lüftern? Oder war das ein Tippfehler?
Markus@AMD
Donnerstag, 14. August 2003, 23:08
woher hat der die Blende vom Aquadrive? kriegt man die auch einzeln? ;D
TrOuble
Donnerstag, 14. August 2003, 23:11
Mail an Support und nachfragen
Cartman87654
Donnerstag, 14. August 2003, 23:12
I know  ;D
WizardD
Freitag, 15. August 2003, 00:31
Kaufe eine große quantität von AquaDrives...
...dann Mail an Support ;)
PAB
Freitag, 15. August 2003, 23:32
Zitat von »Dr._Mohr«
WOW :o
nice work :D
So langsam wirds ein wenig lächerlich. :-/
Glaubt ihr, hier besseres Englisch sprechen zu müssen als Deutsch?
Is nich böse gemeint, aber dieser Entschuldigungswahn greift in diesem Forum langsam um sich :)
