• 02.10.2026, 07:01
SpeedyGonzales
Frontplate for multiswitch in black?
Sonntag, 21. Dezember 2008, 01:06
Is there any frontplate for multiswitch in black?
I see there is a frontplate Aquadrive x4 :rolleyes: , but no for multiswitch..... ;(
Sonntag, 21. Dezember 2008, 01:24
I think aqua-computer had anounced to make some blak multi-switch-plates, but there is no frontplate in the shop. Maybe you can order a plate if you request one by the support-mail (info@aqua-computer.de).
Man In Blue
Sonntag, 21. Dezember 2008, 02:30
We do not offer a black front for the multiswitch ;)
drbo
Sonntag, 21. Dezember 2008, 22:34
This is a returning question (Black Multiswitch ?), and the answer from AC is still NO.
But you can drill holes in a frontplate for aquadrive, (2mm and 3,5 mm holes if I remeber correctly) as I did
The only problem with this solution is that the 4 pre drilled fixing holes dos not fit, so after drilling new holes, the old ones might show a little ...
drbo 8)
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »drbo« (22. Dezember 2008, 04:10)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
