• 25.11.2026, 02:27
drbo
My workstation, complete watercooling
Montag, 22. Dezember 2008, 03:24
thought I should share my updated workstation with you.
It is completely watercooled, and all waterblock and control system from AC.
Hardware: Asus RampageExtreme, QX9650@4GHz, 4GB Ocz DDR3 1600, AsusEAH4870X2, 2x WD RAptor 74GB Raid0, 2x WD 320GB 7,2k disks Raid1, Mist100W Rev3.
Watercooling:
CPU - Cuplex HD
NB and SB: Twinplex XT di
Mosfef: 2x Cooler for voltage regulators for ASUS, copper ed.
RAM: 2x Ramplex
HDDs: 2x Aquadrive dual
Poweradjusts: 2x Cooler for voltage regulator for ABIT-Mainboards
Aquatube
Rads: Thermochill PA120.3+Ac EvoPro 240 + Thermochill PA120.1, all with Noctua NF-P12
Pumps: 2x Laing DCC-1T (moddet to 18W)
Aquatube
Tubemeter
Flowmeter, 5,6mm
Aquaero, with powerconnect
2x Poweradjust
Multiswitch for light an chassis fans
LianLi PC-G70 (inspired by the AC set)
And her some pictures, enjoy:
For full size pictures, see thisthread ...
My water temp is fairly stable at 30c, cpu at 40C, mobo32 , nb and sb 30, and gpu 38C at iddle. Somewhat higher during full load.
The rig does 15 333 in 3DMarkVantage.
A merry xmas and happy new year to everybody.
drbo 8)
Dieser Beitrag wurde bereits 5 mal editiert, zuletzt von »drbo« (22. Dezember 2008, 04:11)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
hobbes_dmS
RE: My workstation, complete watercooling
Montag, 22. Dezember 2008, 12:19
i like that front... ;)
what's behind it?
- 2 aquadrives (obviously)
- a CD/DVD drive (i guess)
drbo
Dienstag, 23. Dezember 2008, 02:31
Behind the front,
aquaero at the top
multiswitch under the auaero.
behind these are the aquatube
then 2x aquadrive dual
then two watercooled poweradjusts, with the flowmeter connecting then (works nice, and eliminates one though bend on the tube).
Below the poweradjusts (hidden) is the singlerad.
As for dvd, I use and external dvd drive when needed (usb).
Glad you liked it ..
drbo 8)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »drbo« (23. Dezember 2008, 02:33)
