• 29.11.2026, 21:49
> Evil E. <
AquaStream XT Ultra dimensions
Freitag, 23. Januar 2009, 00:41
I am trying to figure out where I can fit the pump in my case with the rest of the water cooling and computer parts. Can someone please post the dimensions (width x length x height in mm) of the AquaStream XT Ultra (without fittings) ? If possible, provide the dimensions with and without the base plate (because from what I can see on the pictures, the base plate looks wider than the actual pump).
When I know these details then I can properly plan everything inside the case (fittings, tubing, wiring, ...) and see if it all fits or not.
Thanks in advance for the info. :thumbup:
fox3
Freitag, 23. Januar 2009, 02:01
My pump is mounted in an awkward place to measure but I was able to get these dimensions from a spec. sheet.
Dimensions:
112 x 72 x 52mm
(L x H x W)
I am going to swap my USB cable over to aquabus this weekend, if you are still in need I can give you the baseplate dimension then.
Ditech88
Freitag, 23. Januar 2009, 02:23
hi here are the dimensions:
with base plate: (wlh
75 x 112 x72mm)
base plate is (wlh 75 x 71 x 7mm)
without base plate: (wlh 52 x 112 x 65mm)
I hope you know that the adapters for in- and outlet are required.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Ditech88« (23. Januar 2009, 02:25)
Use your aquadrops :thumbsup:
> Evil E. <
Freitag, 23. Januar 2009, 11:56
Thanks a lot for the help, folks !!! :thumbsup: Now I can get to work trying to figure out the best possible way to place everything.
Hopefully everything will fit in my little case... :S
