• 29.11.2026, 15:16
HollowMac
Regulate manually the Aquastream XT
Donnerstag, 19. Februar 2009, 16:08
Hello,
Excuse me if my english is bad, but i am french.
I am interested in the Aquastream XT, but i have some questions :
the Advanced version have this fonction in more that the standard version :
Manually configurable fan output
What is it ?
It permits to connect a fan to the pump and to regulate this with Aquasuite ? Or it permits to connect the pump to a rheobus and to regulate Aquastream manually ; or to connect the pump to the motherboard and to regulate Aquastream with SpeedFan for example ?
Tank you. :)
cuto8
RE: Regulate manually the Aquastream XT
Donnerstag, 19. Februar 2009, 16:26
Ça ne fait rien - mon francais est sûrement plus terrible ;-)
What is it ?
It permits to connect a fan to the pump and to regulate this with Aquasuite?
It even allows to connect more than one fan, when using an Y-adaptor. You can also let the Aquastream/-suite controll the fanspeed automaticly!
HollowMac
Donnerstag, 19. Februar 2009, 16:40
Ok. Thanks. ;)
The Ultra version permits to regulate the speed of Aquastream with an externaltemperature sensor ; but if i use a sensor for my CPU, it's not very precise. It's better to use the internal sensor of CPU and to get back it with a soft. It is pity that Aquasuite doesn't permit to get back this and regulates the pump. Unless I make a mistake ?
cuto8
Donnerstag, 19. Februar 2009, 17:00
Ok. Thanks. ;)
First of all you should remember that the ultra-version already has an internal temperature-sensor. And the actual idea behind the external sensor was rather not to use a sensor for the heat of your CPU. As the CPU may have a very high variation in temperature it also wouldn't really make sense as your fans would increase speed everytime you start a programm. You should better use this sensor.
HollowMac
Donnerstag, 19. Februar 2009, 21:35
Hum ok ; i understand now.
Thank you very mutch for your explanations :thumbup:
I have already a sensor, and I find that it is difficult to adjust something from the temperature of the water. I know the limits of temperatures of a CPU, but of the water ?(
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »HollowMac« (19. Februar 2009, 21:39)
Papa_Schlumpf
Freitag, 20. Februar 2009, 15:16
Well... Limit...30~35C° is a good temperature. :thumbup:
HollowMac
Sonntag, 1. März 2009, 23:03
Eventually, i took a standard version 8)
But, i have another question : what means "deaeration mode" ? The fact of removing air bubbles, or the fact to purge ?
Thanks.
Sonntag, 1. März 2009, 23:18
In deaeration mode the pump continuously starts and stops. In the starting phase there is a small twitch which can move unwanted air bubbles. So if you run it a few minutes you will get rid of the most air in the loop.
