• 12.11.2026, 22:31
nicky_82
Help please..
Montag, 23. Februar 2009, 00:35
Hi Guys
I was wondering if you could help me kind of confused ?( now what I'm doing is am going to be running these items right?
aquaero 4.00 USB Fan-Controller, VF-Display
Aqua Computer Poweradjust USB can I run two pumps of this ? also what's the dif between this and the multiswitch USB 1.41 and also can I run everything of a multiswitch USB 1.41
my res will be a aquatube also will be using a tubemeter USB fill level sensor
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »nicky_82« (23. Februar 2009, 00:42)
Swing Swing :P
Montag, 23. Februar 2009, 21:34
The poweradjust can only handle one pump. Two pumps generate too much load and will damage the poweradjust!
The multiswitch was mainly designed to switch things on or off, or to dim them in 26 steps. You can not use it for a Laing pump.
I would recommend to connect the tubemeter to the aquaero. You will need a special cable to do so: http://shop.aquacomputer.de/product_info…roducts_id=1969
nicky_82
Mittwoch, 25. Februar 2009, 13:35
thank you
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »nicky_82« (5. März 2009, 15:40)
Swing Swing :P
