• 29.11.2026, 22:19
WebMaximus
Broken Aquaduct 240 PRO...?
Donnerstag, 5. März 2009, 16:14
Today when I started my computer my Aquaduct 240 PRO didn't start with the computer as it usually does, the pump nor the fans are running and I'm only lucky I noticed this right away so I didn't boil my computer.
Any idea what might have happened and how and if I could possibly fix it? I really hope I don't have to send in the unit for repair because I use my computer every day. I have verified I have current at the end of the 15-pin power cable that goes into the Aquaduct so I guess whatever is wrong it's within the Aquaduct. Guess I could try to take the Aquaduct apart and see if I can find out what is wrong myself but thought I would ask you for advice before doing so.
Thanks alot in advance for your help!
Richard
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »WebMaximus« (5. März 2009, 16:22)
Top_Nurse
Donnerstag, 5. März 2009, 20:19
Be very careful about taking it apart as it is difficult to go back together. Does this unit have an Aquaero?
WebMaximus
Freitag, 6. März 2009, 04:00
Not sure what an Aquaero is but if you mean a LCD display of some kind, no it doesn't have that. However I after posting my first post dared to boot all the way into Windows after my CPU had cooled down. Reason I wanted to do this was to check what the Aquasuite software would say but it didn't even find my device anymore so I guess that pretty much says it all...my Aquaduct device for some strange reason is totally dead so now I'm waiting for a response from aquacomputer support how to solve this as easily and quickly as possible because I only had my device for a couple of weeks and I expect the lifespan to be a little bit longer than this...!
