• 23.11.2026, 01:40
Sniper101
Need some good advise for wc
Montag, 18. Mai 2009, 01:32
Hi folks this is my first post here so bare with me :)
After researching the internet for a good quality wc set, first i wanted the swiftech mpc 655 pump but after some reply's in other forums it is not as quiet as the Aquastream XT pump a silent pc is what i want plus the mcp 655 has 24WATT means more heat output.
Anyway i want to cool my cpu and gpu i have 4 questions hope one of you can answer these questions for me.
This is what i have in mind a Aquastream XT pump, Aquacomputer AquagraFX GTX 260 gpu block, CPU block.....?, Swiftech micro reservoir rev2, Swiftech mcr320 radiator. compression fittings, feser tubing. and 6 Noiseblocker 120mm fans.
1: Is the Aquastream XT so much more silent then the Swiftech mcp 655?
2: I want to use all of the components (cpu & gpu) with Aquacomputer parts, but i read that the aquacomputer cpu blocks are of the restrictive kind if it where a cpu only wc set that wouldnt be a problem, but i want to watercool the gpu as well. So can the Aquastream XT pump handle one of your cpu blocks together with a gpu block without problems and if so what core i7 Aquacomputer cpu block do you recommend?
3: Can i use compression fittings 3/8" ID G1/4 (like Feser, Koolance or Bitzpower) to fit in one of your i7 cpu blocks or gpu blocks without having issues concerning "space" (inlet-outlet holes)? like on of these:
http://www.thecoolingshop.com/product_in…roducts_id/2959
4: Do you think the Aquastream XT pump will fit in a Lian li without problems? really love this case see links:
http://techreport.com/articles.x/16258
http://techreport.com/articles.x/16258/2
http://www.overclock3d.net/gfx/articles/…3100134965l.jpg
Thanks in advance.
Sniper101
Montag, 18. Mai 2009, 01:44
I have posted this thread in the english forum sorry for posting it in the german section, you can delete this post.
edit by hobbes_dmS: Need some good advise for wc
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »hobbes_dmS« (18. Mai 2009, 07:37)
