• 09.10.2026, 18:18
pgr13
good advice for flow sensor.
Mittwoch, 27. Mai 2009, 01:22
Hello!
I have a couple of questions.1st will the Koolance INS-FM17 coolant flow meter work with the aquastream XT ultra and its software?
2nd the ultra water pump ,does it suck from the front or the top?
3rd do I need to register my aquastream XT ultra pump for any warranty purposes ?
Thank you!
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »pgr13« (27. Mai 2009, 01:25)
Mittwoch, 27. Mai 2009, 15:06
Welcome to the forum :)
1.) Do you have any technical data about this sensor. Escpecially its working voltage and the number of impulses per minute?
2.) It sucks from the side.
3.) No, you don't need a registration. The only real important thing is the invoice - keep it at a save place.
edit: that could be interesting for you.
pgr13
Mittwoch, 27. Mai 2009, 18:23
thanks! that was interesting.
does AC have there flow meter available in the US and were can I purchase it?
I would rather use AC flow meter than Koolance flow meter.
I only like Koolance blocks and fittings.
Everything else is AC.
Thanks Shoggy for your help
Koolance flow meter --http://www.koolance.com/water-cooling/pr…?product_id=740
Mittwoch, 27. Mai 2009, 19:35
http://www.sidewindercomputers.com/ should have it in the next few days.
pgr13
Donnerstag, 28. Mai 2009, 01:46
Thanks !
I will be waiting for it.
ronaldo
Montag, 1. Juni 2009, 07:08
Thanks for sharing such useful info
