• 13.10.2026, 18:36
GalileoFigaro
Some Question About Aquaero
Montag, 6. Juli 2009, 23:40
Hi, i´m thinking do a liquid cooling with Aquacomputer Parts, but i have some questions.
1 - Can i use a usb hub for connect the aquaero, aquaswitch, tube meter, aquastream XT etc...... i have some free usb in my mainboard and i don´t want loose¡¡¡
2 - Can i use the poweradjust USB with Laing D5 Pump? or other pump with similar specifications?
thanks
MrToad
RE: Some Question About Aquaero
Dienstag, 7. Juli 2009, 00:10
Tonight I fired up for the first time the Aquastream XTs, Aquaero, Poweradjust and Multiswitch. They're connectec to a USB hum that I've conveniently placed inside the case. All of them are recognized by the sofware. However, I haven't had time to check if all functions are operational, or to check for long term consistency (I've, quite literally, just fired them up).
Yes and no. The Poweradjust can provide (according to the manual) 2.5A, sp that's enough to power a D5 or a DDC 3.2/3.25. However, most pumps (except one certain competitor's iteration of the DDC 3.25) come with a four pin "molex" connector, male, with two pins populated (12V and GND). The power connector in the poweradjust in the three pin connector you usually find in MB fan headers. Therefore you have to either termintate the cable accordingly, or source a 3-pin to 4-pin adaptor.
