• 29.11.2026, 21:49
dhc0329
Question regarding positioning of Aquastream XT
Dienstag, 4. August 2009, 15:32
I just got my 2nd Aquastream pump to replace the weak pump in Zalman water cooling system LQ1000.
Due to the tight spacing issue, I couldn't place the pump in upright position but had to lay the pump on
the side way in the case.
My pump seems to work fine laying side way but just wanted to make sure if this would cause any issue.
fox3
Dienstag, 4. August 2009, 16:32
I have one of mine installed on its side in my case since January running 24/7 with no problems to date. The other is in line with it and no difference in output between the two.
dhc0329
Dienstag, 4. August 2009, 17:49
Thanks, Fox3...that's what I figured but just wanted to make sure..
