• 29.11.2026, 21:18
dimdar
Aquaduct XT 720 - Pump start slow
Donnerstag, 6. August 2009, 10:28
I have some questions on the pump of Aquaduct XT 720:
Every time I turn on aquaduct (I am test it for now) the pump start form 60Hz and increase slowly to 80Hz (maximum), after the pump go down to 60Hz and restart to increase to 75.5Hz. Ok, the pump searches the best compromise but why every time? Why it start from 60Hz If I have specified minimum 70Hz? 8|
I am test it and for now I have not water block along the circuit so liquid go out and come in after 4mt of tube (ID 10mm). I have the sensation that fluid move slow at 75.5Hz (100 l/h) and too slow at 60Hz (64 l/h). Is sufficient 1.6 liters at minutes for cooler cpu (QX9650@4.2Ghz), chipset, vrm, ram and 3xGTX 285? ?(
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dimdar« (6. August 2009, 10:29)
:thumbsup: MB: EVGA 780i FTW / CPU: QX9650@4.0GHz / RAM: 4GB - CORSAIR TWIN2X4096-8500C5DF (Ver 2.2) linked at 1066Mhz / NVidia GPU Ex: Enabled / SLI-Memory: Expert / VGA: 3xGTX 285 / HD: 150GB WD Raptor + 1T WD Green / OS: Vista Ultimate 64 bit
Freitag, 7. August 2009, 10:29
The pump needs some time to get a higher speed. You also won't start your car and have 100mph in the first second ;)
Make sure to disable the automatic frequency setting and select the manual mode.
