• 13.11.2026, 08:58
Pumpkin
Aquaero Settings
Montag, 10. August 2009, 13:18
I need some help to help set up my system using the Aquasuite.
I wish to set up my system such that when my flow meter drops below a certain level then my pump will shut down.
I have the Aquaero with powerbooster. So my Liang 3.25 Pump will be connected to the Aquaero.
I will have the A.C flow sensor connected also to the Aquaero.
Can someone please show me a step by step guide for the correct settings in my aquasuite.
Thanks
fox3
Montag, 10. August 2009, 21:59
Why would you want your pump to shut down? Do you have the tach signal from the pump set up so that when it shows zero the PC shuts down?
Pumpkin
Dienstag, 11. August 2009, 08:23
My concern is if I get a leak overnight then my flow would drop (I am using the Aqua Computer Flow meter to monitor this) and I would want the system to shut down.
