• 04.10.2026, 02:30
Cyberdyne
Whether repair my pump?
Dienstag, 11. August 2009, 18:02
Confronted with an issue. Improperly connected cable USB pulling the +5 V is on the other connector (Pin 4 D-). Then, of course, ceased to operate the software. I want to ask - my pump is beyond repair or electronics will not recover?
I lifted the hood and checked all the diodes. This diode was burned. Unfortunately, I do not know what the face value can be replaced. Here is his picture:
Please forgive me for my English - it is not my native language. I look forward to a reply.
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Cyberdyne« (11. August 2009, 18:06)
Cyberdyne
Mittwoch, 19. August 2009, 11:32
Defence1
Freitag, 21. August 2009, 08:44
send it over to Aqua Computer, they can repair your pump. you can fix it even by yourself, simply change the diode.. The type can be named by Aqua Computer....
Mein System:
Cyberdyne
Montag, 24. August 2009, 18:03
Thanks, I'll try to replace the diode itself. Are transferred to other countries are very far (and expensive).
Cyberdyne
Montag, 24. August 2009, 18:07
Sven - thank you for additional information, I hope it will help
PvHooijdonk
Dienstag, 25. August 2009, 14:17
The same thing happened to me some time ago.
Due to the fact that I did not notice in time that the colouring of the usb wiring was different than standard.
I tried to change the zener-diodes myself but was unsuccesful.
I ended up buying a replacement print plate for the pump via AC.
Professional Crasher :thumbsup:
kolsols
Samstag, 12. September 2009, 07:54
yes pf course simply replace your burnt diode with a new one and your pump would be fine.
Cyberdyne
Montag, 14. September 2009, 20:56
I ordered a new diode - it will be soon to come. After replacing the diode, I will inform the result of repair
mans123
Donnerstag, 24. September 2009, 09:06
hope it would be fine.
copcop
Montag, 12. Oktober 2009, 11:53
I think you should buy a new one instead of repairing it. :P
Top_Nurse
Dienstag, 13. Oktober 2009, 03:06
Why? There easy to fix. :thumbsup:
funkyfresh123
Freitag, 30. Oktober 2009, 10:54
just try to repair it...as it would be cost effective.
Cyberdyne
Sonntag, 8. November 2009, 10:16
Replacing the diode has not helped. Died controller (((
The controller has been filled with resin. Had some work to clean it.
The question now is - if I changed to a working chip (ATMEL), will need special firmware or will be enough this - aquastream XT-Firmware 1.09, DIY-Flasher?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Cyberdyne« (8. November 2009, 10:29)
Montag, 9. November 2009, 16:35
That will not work in any way...
You will need a completley different firmware.
brianmoore123
Mittwoch, 11. November 2009, 11:55
I think someone has already advised you not try to repair
