• 28.09.2026, 22:04
Pumpkin
Temperature sensor: Product Code 53067
Donnerstag, 13. August 2009, 21:55
Hi I purchased one the above temp sensor which is connected to the inlet of my rad.
The problem I am having is the the aquasuite tells me the sensor temp is 3-5 degrees which is clearly wrong.
I used some of the other sensor which came with the aquaero and they seem to report the temps fine in the aquasuite
Is the sensor just broken or can it be fixed some how
Thanks
Donnerstag, 13. August 2009, 23:45
Very likely that it is broken. Contact your dealer for an exchange or us if you bought it in our webshop.
Pumpkin
Freitag, 14. August 2009, 08:52
Thanks
