• 30.11.2026, 15:56
Pumpkin
Aquaero Power Connect & Relay Query
Freitag, 14. August 2009, 08:51
I am trying to set up a emergency shutdown of the PC
I am using the following accessories, Product No.: 53047and the Product No.: 53036
I connect the Standby Power cable into the Aquaero
I cut the green ATX PS_ON line and attach the Relay plug and connect it to the Aquaero
I turn on the PSU
The problem is when I try and power on the PC nothing happens. (I am using the onboard power button on the EVGA E759 Classified MB)
However if I reconnect the ATX PS_ON line without the Relay Plug then the PC will boot up fine with or without the Standby Power plug connected to the Aquaero.
What am I doing wrong....
Dieser Beitrag wurde bereits 3 mal editiert, zuletzt von »Pumpkin« (14. August 2009, 09:19)
Freitag, 14. August 2009, 09:52
Have you set the jumper on the aquaero for the standbypower?
Pumpkin
Freitag, 14. August 2009, 10:05
