• 23.11.2026, 00:18
Top_Nurse
Standby power question
Freitag, 11. September 2009, 00:39
I believe this is a Shoggy pic IIRC. What I'm wondering is whether I can just run a single wire from the power loom (violet wire) and just pickup a black (negative) wire up on the Aquaero somewhere (probably one of the 4 pin molex connectors)?
Freitag, 11. September 2009, 09:26
Ground is ground is ground is ground :D
It doesn't matter which ground wire you use.
Top_Nurse
Freitag, 11. September 2009, 15:11
Thanks Shoggy! I took apart a PSU a while ago and noticed that all the black wires were soldered into the same part of the circuit board. Just wasn't sure this was common procedure. :)
