• 10.11.2026, 20:56
Top_Nurse
AC Filter bleeding woes
Donnerstag, 1. Oktober 2009, 12:40
Put a new filter into my CPU loop and having troubles getting the air out. Have tried every which way to bleed out the air and can get them out. I have the right side going in and the left side going out.
HELP
Top_Nurse
Freitag, 2. Oktober 2009, 02:21
FIXED!
There appears to be an inlet and an outlet. If you hook it up backwards you get the air display (looks kind of cool). So the if you have the unit face up and the G 1/8 connectors facing you, then the intake is on the left side and the output is on the right side. Perhaps the web store already says this, but it wasn't discernible to me.
Added:
I obviously need better light or new glasses as the in/out is marked on the back of the unit. ;)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Top_Nurse« (3. Oktober 2009, 03:53)
