• 12.10.2026, 02:30
Rook85
Windows 7 help please
Freitag, 4. Dezember 2009, 07:55
I am running an ASUS M2N SLI deluxe M/B with an Nvidia 570 series chipset i just got a aquacomputer cooling system i can not get aquasuite to work i have the 4.66.x version the unit runs fine circulates nicely but i have no software control and windows cant find the drivers for it please help
cuto8
Freitag, 4. Dezember 2009, 08:29
Are you running the 32 or 64bit Version?
Rook85
Freitag, 4. Dezember 2009, 11:46
32 bit sorry i didnt think to post that before... and i tried runnin virtual XP didnt seem to work its not recognizing my USB driver it says theres a device there just cant get the drivers for it
Scaniris
Sonntag, 6. Dezember 2009, 02:57
Hello,
Have a look there: Aquaero : this peripheral can't start. (Code 10) - USB issue ... with ASUS and EVGA MB!!!
I think you have the same problem....
I've ordered a PCI USB controller from the Aquacomputer webshop and... it's runnning now....
IMO the Aquaero controller has a specific USB type that has some troubles to properly run with Asus or Evga motherboard.... :evil:
It's not OS related, I tried with Vista 32, Seven 32 and 64, and also XP only for testing this issue....
Rook85
pci express usb card
Dienstag, 8. Dezember 2009, 22:35
so i ordered a PCI express usb card i will try and post results in new thread if it works so it will be easy for others to find =)
Rook85
USB card
Montag, 14. Dezember 2009, 22:05
i installed a PCI USB card and to no avail. the drivers for the aquero USB wont install error code 43
Weihnachts-Shoggy
Dienstag, 15. Dezember 2009, 17:32
The aquaero does not need any drivers. It is programmed as a so called HI-Device like a mouse or keyboard so any operating system must be able to detect it. If it does not work there MUST be another problem. Do you have the option to test it with another computer?
