• 29.11.2026, 21:21
ktseymour
Aquaero LCD screen flashes?
Freitag, 11. Dezember 2009, 22:41
I just Installed the Aquaero V 4.0, and the screen won't quit flashing? I'm almost 100% certain I hooked It up right using Shoggy's Instructions from Xtremesystems forums. I hooked up both the Aqua stream and the Aquaero via the USB ports on the board. A short while after I hooked up the Aquaero I can no longer run the software without getting dozens of USB error reports from Aquasuite. Nice hat by the way Shoggy 8)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »ktseymour« (11. Dezember 2009, 22:43)
ktseymour
Samstag, 12. Dezember 2009, 18:42
Here we go again :pinch:
ktseymour
Montag, 14. Dezember 2009, 00:32
T..wenty six, ah,ah,ah!!!
I can stay at home and be Ignored. :cursing:
Weihnachts-Shoggy
Dienstag, 15. Dezember 2009, 17:35
So the LCD constantly turns on and off?! Never heard of something like that before. Try a reset: shut down the system, press and hold the middle button (set) and start the system. After 2 - 3 seconds you should read a reset message on the LCD. Maybe it helps.
ktseymour
Mittwoch, 16. Dezember 2009, 21:14
I'll give that a try Shoggy.
ktseymour
Samstag, 19. Dezember 2009, 20:32
I wonder If this could be a power Issue also? I'm going to double check everything today as far as connections and different power connections.
If these things and the reset don't resolve this does anyone have any other Ideas what could cause this? Could It be the USB Issue I've read about here?
:P One smiley a post until Christmas. It's not every day we get smileys with Santa hats, or Shoggy's for that matter :D
Okay, that's two. I lied :whistling: Three....
ktseymour
Sonntag, 20. Dezember 2009, 06:12
:thumbsup: Got It working Shoggy.
It was either the reset or the power Issue, maybe both?
Thanks for the help Shoggy
Weihnachts-Shoggy
Montag, 21. Dezember 2009, 22:55
Great to hear that it is up and running again :thumbsup:
Top_Nurse
Mittwoch, 23. Dezember 2009, 09:41
It was the reset that did it. Sometimes these controllers get odd information stored in them. A factory reset clears all the data banks.
ktseymour
Mittwoch, 23. Dezember 2009, 19:44
It died TN, It was a bad unit from the get-go.
