• 17.11.2026, 16:04
CoolerM
Aqueduct mark III 720 XT not working
Freitag, 11. Dezember 2009, 23:19
Hi everybody
I bought used Aqueduct 720 XT for my water cooling project but after couple days of using I discovered flow error.Problem was with pump and this rubber things where rotor is spining, I bought new one frome aquacomputer and that one haven't got rubber so is spinning wit less resistance.After connection was working without any problem but next day screen on aqueduct was showing again "pump error",I checked aquasuite and I found strange readings frome pump like a 655,4V,655 C temp and 246 L/m but after 2 minutes was ok and then again.I checked firmware and was 1018 on pump so I download 1019,flash new one and everything was looking good.I decide to restart,and when windows powers up I turnh nob on aqueduct and accidently put "Overide" option on position +1,after that fans was spinning on maximum and aquasuite can't see aqueduct in windows.So I turned off everything wait some time,turn up again and screen and leds didn't turn up,only pump is working,also aquasuite can't connect with aqueduct.After pressing overide option this aqueduct motherboard is death?I don't understand ?( .My aqueduct is manufactured in february 2009 so maybe I can send this board for inspection?Thanks for any ideas
Weihnachts-Shoggy
Dienstag, 15. Dezember 2009, 17:24
Sounds a bit like a problem with the controlling unit. Have you tired a reset? To do so shut down the system, press and hold the controlling knob and start the system. If it works you should see reset message in the LCD after 2 - 3 seconds.
If that does not help I would recommend to send in your aquaduct for a check/repair.
CoolerM
Dienstag, 15. Dezember 2009, 17:55
Hello and thanks for answer to my problem.Yes I try to reset with no change also I contact aquacomputer but I have to send whole unit what is impossible for me because will cost a fortune.Only hope if I can send cotrol unit or buy one frome aquacomp.
