• 16.11.2026, 12:58
dxb750
Aquaero 4.00 USB Controller with Swiftech MCP655 Pump ?!
Sonntag, 20. Dezember 2009, 02:34
Hello everyone,
I want to buy this items :
1- aquaero 4.00 USB Fan-Controller, VF-Display with powerbooster
http://shop.aquacomputer.de/product_info…roducts_id=2357
2- Flow sensor "high flow" G1/4 for aquaero, aquastream XT ultra and poweradjust
http://shop.aquacomputer.de/product_info…roducts_id=2294
3- Temperature sensor inline G1/4 for aquaero, aquastream XT and aquaduct
http://shop.aquacomputer.de/product_info…roducts_id=2291
But I want to know if it works with the pump well : Swiftech MCP655 12v DC Pump with Speed Controller
And what is the maximum of pumps and flow sensor, which can make is with the Control ? and do I need special wiring or the like so that I can control pump ?
Thank you,
Weihnachts-Shoggy
Montag, 21. Dezember 2009, 22:47
Don't forget to order the necessary connection cable for the flow sensor.
The pump will work with an aquaero + powerbooster. You can only connect one pump to fan channel 1 because otherwise the load is to high and will damage the aquaero.
You can connect a second flow sensor to fan channel 4 if you reconfigure it to be used with a flow sensor. Of course in this case you won't be able to use it for a fan anymore.
dxb750
Freitag, 25. Dezember 2009, 10:57
Thank you for your help "Weihnachts-Shoggy"
I will buy the cables, and I will use 2 Flow sensor.....
And also I want to know how I can benefit the "poweramp" with aquaero controller :
poweramp Verstärkerplatine für aquaero und aquastream XT
http://shop.aquacomputer.de/product_info.php?products_id=2363
it allow to use more than a fan or pump with single channel in the aquaero controller !? :?: :!:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dxb750« (25. Dezember 2009, 11:47)
Weihnachts-Shoggy
Freitag, 25. Dezember 2009, 17:46
As long as you don't exceed a load of 10W per channel (15W with powerbooster) you can also connect a few fans via y-adapters to one fan output. Keep in mind that the total load should not exceed 30W or 45W with powerbooster.
With a poweramp you will have almost no limits (up to 42W) but you will always have a voltage drop of 1.5 to 2.0V. If it doesn't matter to you it might be interesting.
dxb750
Samstag, 26. Dezember 2009, 11:33
Thank you for your advice.... :)
I have done a simple design, which I want to do .....
Can I do that ?!
»dxb750« hat folgendes Bild angehängt:
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »dxb750« (26. Dezember 2009, 12:08)
Weihnachts-Shoggy
Samstag, 26. Dezember 2009, 12:54
That will not work. The poweramp must be connected directly to the PSU and the fan connectors are IN and OUT. You connect IN with one of the fan channels of the aquaero and at OUT whatever you want to power.
I also did not recognize that the MCP655 is the Laing D5 which in my opinion draws too much power. It might work for a while but I think by time it will damage the aquaero.
