• 06.10.2026, 04:35
heed
Aquaero data on Samurize in W7x64?
Sonntag, 20. Dezember 2009, 08:44
Hi, has anyone been able to get the data from their Aquaero displayed in Samurize using a 64-bit OS? I think that some of the dll's might be incompatible, but I could be setting it up wrong. Help?
Weihnachts-Shoggy
Montag, 21. Dezember 2009, 22:56
Afaik Samurize has no official support for Windows 7. You can try to install it as admin and start it in the XP compatibility mode.
heed
Mittwoch, 23. Dezember 2009, 09:36
hey, Shoggy, Merry Christmas.
Ya, I got Samurize running no problem on W7x64. And, I also got the newer version of the AC plugin from your downloads area working. Not all the functions work though.
Now, I'm just trying to get the Aqualite plugin to work. Some of the libraries it requires I believe are not 64-bit OS compatible, so it may be a no-go.
On a side note, I managed to burn out my VFD in the process. :(
taloche_aqualite
Mittwoch, 23. Dezember 2009, 15:11
Do you speak of my samurize plugin "aqualie" ?
