• 29.11.2026, 21:19
disturbed13
aquaero questions
Mittwoch, 20. Januar 2010, 22:06
1) is the aquaero supported for use in Damn Small Linux?
2) Can the aquaero handle 3 of the Scythe 'Slip Stream' 120mm 1600 rpm case fans, 12V @ 0.41A
3) What are the system requirements of the aquaero?
4) And what is the open source command tool?
thanks guys
Mittwoch, 20. Januar 2010, 22:20
1.) The aquaero is programmed as an HI-Device and acts like a keyboard or mouse. So you won't need any drivers but of course you will need software to take control. We do not provide any software for Linux but one of our customers has programmed a tool: http://breakbe.at/development/aquaero/
2.) Three of these fans on one channel will not work with a regular aquaero. The maximum load for each channel is 10W while the overall load of all channels combined should not exceed 30W. If you take the variant with powebooster each channel can do 15W (= the load of the mentioned fans) and the overall load is 45W.
3.) None :D Since it is a stand-alone device with its own CPU and operating system you would not need a PC. Of course if you want to use the software every PC with USB and Windows + .NET Framework will be enough.
4.) You can download the SDK + documentation here.
disturbed13
Sonntag, 24. Januar 2010, 06:09
thank you for the reply
now i have some technical questions that the instruction manual does not tell me
i need to know the dimensions of the Aquaero LT 4.00 (thats with-out a display and case)
in millimeters if you could
no stand-offs
height x width (the shorter) x length
thanks again :D
Montag, 25. Januar 2010, 15:01
143 x 41 x 27.6 mm
