• 22.11.2026, 22:16
osborne3
Switching out LED's for the Aquaero
Sonntag, 4. April 2010, 08:28
OK so here is the dealio I want to switch up the LED's on my "Multi-Color Illumination module BLUE / RED" so it is GREEN / AMBER. So basically what I need to know is what voltage the Aquaero LED power source is at? So I can add the appropriate resistor if nessasary. Happy Easter THNX :)
Top_Nurse
Mittwoch, 7. April 2010, 10:59
I hooked mine up to a tri-color LED and it worked just fine, but I didn't like the amber lighting. Now I use a green/red LED. In both cases I didn't bother adding in a resistor. Besides you can adjust the brightness (voltage) with the Aquaero.
