• 11.11.2026, 04:32
Sniper101
Aquastream XT error
Mittwoch, 14. April 2010, 02:29
Dear Aquacomputer,
After just 3 good day's the pump would not start all went well with idle temps of arround 23 C and very sillent. I was really happy. When i started my pc i after 4 min i smelt something bad so i opened my case and it was the pump. And to my horror there was no flow. And the red light was burning. I did all the problem solving in the manual including the jumper. I tried it 4 times but no way i'm going to damage my cpu it quickly rose to 96c at that point i shutt of the pc. Anyway nothing helped...so i was forced to drain my pc! I should expect the pump working after 3 days...all the hard urned money and work i spend. I still have my warranty.
And now i'm a unhappy costumer.
What to do now?
Pleace help,
Thanks in advance.
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »Sniper101« (14. April 2010, 02:35)
Mittwoch, 14. April 2010, 06:54
I think you must take up contact with your dealer(or aquacomputer) and send the pump.
