• 10.10.2026, 15:35
WebMaximus
msi N480GTX and aquagrafx 480...a good working combo?
Freitag, 14. Mai 2010, 10:06
Have someone in here already tried the new aquagrafx 480 water block on msi's N480GTX M2D15 card or can someone confirm it works? I'm thinking of buying this combo but just want to make sure I don't end up with a mix that for some reason doesn't work but as I understood it msi is following Nvidias reference design and that in turn should garantee that the aquagrafx water block will fit on the msi, correct...?
Thanks in advance for your advice!
b0nez
Sonntag, 16. Mai 2010, 23:16
as long as the design the reference design there should be no problems using the block with your card
:rolleyes:
