• 11.11.2026, 12:21
llecaroz
[enhencement request] Sensor calibration based on two points ?
Dienstag, 1. Juni 2010, 08:09
Hello, I am really suprised by the calibration feature of the aquasuite/aquaero for temps sensors.
Normally, best calibrations systems are based on two points, a lower & highter point...
This allow to change the curve orientation/angle. From what I tried in the aquasuite, this appears not to be possible :(
& so on, you cannot calibrate your temps sensor regarding the CPU curve & the precision is not quite good !
So I hope that I was able to communicate with you the need of this feature as it is really missing in your product.
By the way, uses can use a sensor on the cpu socket reporting temps really lower than the one reported by the cpu but by calibrating them on two points, aqauasuite/aquaero could report a temp really similar to the cpu as calibrated on two point & having the correct curve angle/orientation...
thx in advance for your feedback
louis
Dienstag, 1. Juni 2010, 19:48
That function is not possible due to technical limitations.
