• 17.11.2026, 23:29
urbtree
Usb connector missing
Dienstag, 1. Juni 2010, 15:04
high all
i`m a noob to this forum so forgive me any faux pas.
my swiftech pump died the other day but luckily i had a an aqua stream as a back up
ive never set on of these up before so i`m looking for a bit of help.
i bought the pump off ebay so i think some of the parts may be missing
i got an IO plate with it that has a molex connector (have)
it also has the pump connector
but there is a usb header on the board and i`m thinking this has to connect to my mother board so i can controll the pump via software, correct?
now there was no supplied usb cable so i`m thinking i`ll have to make one.
i`m worried about how it connects.
do i make a cable to go from the usb header on the braket to the mobo.
also due to the fact that my last pump failed while i was out for the day i`m very interested in the auto shutdown feature of this pump and would like any info i can
thank in advance for your help on this guys
Dienstag, 1. Juni 2010, 15:08
This is not a USB connector.
Please read this:
Aquastream 3.5 Manual
urbtree
Dienstag, 1. Juni 2010, 16:50
ok so now i know wha its called can you tell me where it would connect to so i can go about either ordering the part or making one
i can connect the pump but it seams to be running slowly and i`d like to use all the features of the pump
Dienstag, 1. Juni 2010, 19:51
This is an old aquastream (non XT!) controller which does not offer any USB communication at all. The only way to use a very small set of controlling options is that you connect it to the aquaero via aquabus (in this case the 10-pin socket).
urbtree
Dienstag, 1. Juni 2010, 21:40
great thatnks for the help guys i`ve read through the destructions and got it working perfectly
hobbes_dmS
Dienstag, 1. Juni 2010, 21:55
pun intended? ;) 8) 8)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »hobbes_dmS« (1. Juni 2010, 21:58)
