• 22.11.2026, 23:14
llecaroz
Donnerstag, 3. Juni 2010, 10:24
Ok ! so I created another record in this forum for my Aquaero being reseted randomly ! from your side, you have problems when your G15 logitech keyboard is connected & from my side, since two days,
I did not power on my Z-10 Interactive 2.0 Speaker System from Logitech, only my G15 keyboard is connected & no more reset & detection issues of my aquaero !!!!!
So from my understanding, there are some conflicts between Aquaero & Logitech USB products containing a LCD to display computer infos !
Is it an Aquaero USB ID issue & Aquasuite bug on detection, as all my others USB peripheral works well, I suppose that yes ?
Is it possible to have a bios/firmware+aquasuite update correcting this ?
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »llecaroz« (3. Juni 2010, 10:27)
Speedy Donderball
Dienstag, 15. Juni 2010, 01:37
Well, it is for two weeks now that I have replaced my G15 keybord and it is still running fine. I have replaced it for a new G19 keybord that displays the same information as before for over a week now but that's no problem either. A friend of mine also had various issues using his G15 and that was over when he replaced the G15 as well.
So it is probably the combination of devices. My G15 is connected to another PC and works like it should.
Damn. All my problems are solved, now what?? There must be something to complain about..... :D
