• 22.11.2026, 23:49
oliverw92
Aquaero power advice
Donnerstag, 10. Juni 2010, 14:38
Hi there,
Sorry i know this is a German forum, but I am English and can't speak German :( I hope it is ok to post in english.
I am considering getting an Aquaero with a powerbooster module, but I am unsure if i would be able to run what i need on it. Here is what i would like to run:
7x Enermax Cluster 120mm fans: http://www.enermaxusa.com/catalog/produc…products_id=141
2x Laing DDC-1T Pro 10W pumps: http://www.watercoolinguk.co.uk/p/12V-La…-MCP350_21.html
I don't mind distributing it all across the channels, but i was wondering if the Aquaero can take that in terms of power?
Thanks,
Oliver
b0nez
Freitag, 11. Juni 2010, 01:05
Hello
The AE can handle one DDC-1T at the same time at the fist chan. The 7 fans should be no Problem as long as you wont connect them to one chan (max output per chan is 15Watts - the first can handle 25W; the power consumption all over chans should not exeed 45Watts)
Yesterday AC introduced the new Poweradjust. With this device its possible to control loads up to 24Watts permanently and 48Watts as peak load. So its perfect for the secoond pump.
:rolleyes:
