• 18.10.2026, 17:36
Raiden_hard
Aquasuite error
Sonntag, 1. August 2010, 04:44
Im having a problem using a aquaero , it´s detected via usb by the computer and it works fine manualy , but i install aquasuite and it doesnt detect it, if i go to detect via usb i get this error:
I
f anyone can help :up:
By the way im using Windows 7 x64
Matt
maybe a solution
Sonntag, 1. August 2010, 13:55
Hi Raiden, and welcome in aquacomputer forum,
i would try to help find a solution to your problem, make in mind i'm not sure 100% to resolve your problem, but i will try...
Follow a step by step istruction and maybe we can resolve your issue, i solved an USB problem with mine aquaduct by doing this.
1: Download and instal CC cleaner ( http://www.piriform.com/ccleaner/download)
2: make a full registry scan and correct the problem founded.
3: remove Aquasuite
4: remove any usb device pluged in your computer (leave keyboard and mouse pluged in)
4: Go into your system device gestion (really don't know the real english name since i'm italian :D ) and remove the USB driver interface where your aquacomputer is pluged in)
5: Restart system and don't PLUG IN your aquacomputer device.
6: Windows will recognise new usb port and will instal back
7: Go to your motherboard hardware house website and download latest MB driver ( usually they release a suite to automatically upgrade many hardware things about your MB)
7a: restart computer
8: plug in your aquacomputer device inside usb port (you will ear a sound) ----> try different USB port if needed.
9: instal back your aquasuite
10: for last make a CC cleaner registry control and clean wrong registry voice.
Hope will help, i solved my USB problem by doing this... :thumbsup:
PS: maybe some step are useless :whistling:
for further help i'm here ;)
Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »Matt« (1. August 2010, 13:56)
Sonntag, 1. August 2010, 15:34
That won't help because the error message clearly states that there is something wrong with the font Arial. As already wrote at XS you should copy all Arial fonts from another PC to yours.
Matt
Sonntag, 1. August 2010, 17:38
hehe shoggy owned me :D :thumbsup:
